Worksheet Overview
The following provides information about Worksheets and how they should be used.
The Adjust view contains a number of Worksheets, these Worksheets are used for configuration and tuning. The Worksheets are located within the Adjust view above the Adjust Items Editor.
- The Configuration Worksheet
this worksheet is locked and appears in all workspaces. - User definable Worksheets e.g.
most Workspaces come with pre configured Worksheets
designed for a defined task.
Creating/editing a Worksheet
A new Worksheet is created blank. The user can then populate the Worksheet with a variety of components that can be placed anywhere on the Worksheet to create a customised layout that suits the application. The components themselves can be moved, resized and customised so that they are appropriate to the Worksheet.
Every component has a unique set of properties specific to that component type. These properties determine how the component looks and behaves. The property values are set within M1 Tune for tuning of the M1 ECU.
To configure the new Worksheet right click anywhere on the background of the Worksheet, choose a component from the dialog.
The component types that are available include:
Examples of gauge type components:
