Resources
I/O Resources
The Resources View combines all the worksheets required for firmware resource allocation, configuration and I/O monitoring.
  • 1 I/O Resources view.
  • 2 Details view.
  • 3 I/O Pins view.
  • 4 I/O Monitor view.
The I/O Resources worksheet lists the Resource name, Pin name, Pin designation and Pin number.
The displayed resources can be toggled between Show All Resources available in the firmware to Show Assigned Only.
The Filter section (Ctrl F) can be used to quickly find a resource from the list.
The Hide/Show Details toggle will show/hide the details view at the bottom of the I/O Resources worksheet.
Details View
The Details View shows the configuration details for each resource selected in the Resources worksheet.
I/O Pins
The I/O Pins worksheet is a pictorial representation of the ECU connectors showing the assigned pins.
Note: The ECU connectors pictured will be the ECU model shown in the package Summary.
When an I/O resource is assigned, the ECU pin will be highlighted in the pinout.
  • White = assigned input/output resource pins.
  • Green = Common sensor 5v and 0v pins.
  • Red = 12v pins.
  • Black = Ground pins.
  • Orange = Currently selected pin.
Note:
  • Hovering the mouse pointer over an assigned pin shows the Resource assigned and the pin name.
  • Hovering the mouse pointer over a greyed out pin shows the pin name.
Clicking on white input/output pins, highlights that resource in the I/O Resources / Details view.
Note: When two pins are required for one resource both pins will highlight orange. E.g. Differential Knock Input 1 uses pins D7 and D13.
I/O monitor
The I/O Monitor view displays the assigned resources, input and output values in the upper section. The lower section displays a time graph specific to the selected resource.
The Auto view within the I/O Monitor displays the relevant channels based on the resource selected.
Note: The green rectangles highlight a rapidly changing value.
