Repair Logging System
M1 Tune has a minimum required diagnostic logged channels set that must remain in place.
Required diagnostic channels have the
icon.
Note: Diagnostic Channels are configured by the Firmware package author and cannot be edited
in M1 Tune.
All channels have a maximum logging rate specific to each channel. When a channel is added to the Logged Items section at a rate higher than its maximum that channel will be in fault.
Use the Repair Log Systems button
from the active component tool bar to perform two
operations.
- To restore the minimum required diagnostic logged channels.
- To reschedule any channels that exceed their maximum logging rate or are logged at an invalid rate.
