Dyno Tuning with M1 Tune
To make engine tuning faster, it is possible to Quick Lambda fuel table values at a point in the past using pause live data, see Live Data Control.
The process is as follows:
- Connect the laptop to the M1 ECU and watch the live data in M1 Tune.
- Ramp engine through the Ramp test.
- Press the T key to pause the live data display.
- Scroll back through the saved data on the Time Graph and review the ramp test.
- When a site (data) is found that needs to
be re-tuned with Quick Lambda, press the Q key. M1 Tune displays a summary window of the action about to be performed. For example:
- Select OK to run the Quick Lambda function.
- Press T to restart display of live data.
