About Package Details
The Open Package window displays a list of offline Packages. The details about each of the offline Packages is shown, these are defined in the following table. Also see:
Details Definition
State Icons indicating ...
Vehicle ID A unique identifier of the vehicle in which the Package is used. The vehicle ID is a useful way to find Package(s) for a particular vehicle.
Serial # The serial number field records the ECU number with which the Package is associated. Whenever a Package is sent to an ECU, M1 Tune will attempt to send it to the matching ECU. If the Package is to go into a different ECU, then the serial number must be changed to the serial number of the receiving ECU.
Comment Comments are used to keep track of changes to the Package over time. This is the recommended method to use for recording the sequence of changes made to a Package. This field assists in selecting the correct Package.
Firmware The firmware property is the name of the firmware group.
Firmware Version Name Used to describe the specific version of the firmware.
Firmware Version An incrementing number that uniquely represents each unique build of the Package.
Hardware This field identifies for which M1 ECU model the Package was built. Each M1 Package is built to work with a particular M1 model. A Package built for an M170 will have a different pin allocation to a Package for an M190.
Modified Date/Time This field records the last time that this particular Package was modified.
Imported Date/Time This field records the date and time that the Package was imported onto the PC.
