Contextual Navigation
To access help:
  • Help > Firmware Context Help...
  • Select an item, press F1
  • Select Show Help from the View Tool bar
The Contextual Navigation pane to the right of the screen contains 4 sections.
Each one of the sections contains text that when clicked on will take you to the item within a Worksheet.
The Guides component has been compiled to step the user through complex configuration processes. See Using Guides.
Note: Not all packages contain the Guides section.
The Review system allows for the marking of parameters to review at a later stage in the engine tuning process. See Using Review.
Help is available throughout M1 Tune by clicking on Parameters, Channels and headings . See .Using Help
Search for all parameters and channels contained within the Firmware Package, the results are listed in alphabetical order. See Using Search.
