Workspace Templates
When a Package is opened, a name match search checks:
- Your locally stored database for a workspace you have previously opened this Package with.
- The matching rule set from MoTeC Online.
If no match is determined, a manual selection pop-up will occur.
This pop-up will allow you to match a particular Package to one of your existing
workspaces.
Note: The pop-up will list the workspaces that exist in your workspace
directory.
Select Create... to generate a new workspace based on a Template
.MTF file import or one you have previously published.
