What is a Workspace
workspaces are stored locally on your PC. Each workspace you create and name will be stored in your workspace directory.
These workspaces can be compressed into a template file (. MTF) for ease of distribution, or to use as a template base for a new workspace. Workspace templates can also be embedded into exported Packages depending on Tune user preferences.
The M1 Tune Workspace is broken down into 4 main areas the user will interact with when using Tune 1.5:
  • Adjust Tree is the workspace navigation menu for the workspace or firmware groups of configuration parameters.
  • Adjust Items / Adjust Items Editor Is the area for the configuration of parameters.
  • Adjust Items Telemetry This is where the ECU telemetry (live data) can be seen.
  • Common Telemetry The common telemetry section displays ECU telemetry data that remains the same regardless of other selections made.
