Active Component Tool bar
The Active Component Tool bar will change depending on the currently focused Component or Parameter.
  • Select a Component within a View (Orange highlighted), the tools relevant to that selection will be available.
  • Select a Parameter (Orange highlighted), the tools relevant to that selection will be available.
Example. Selecting a Time Graph component in any View, will show the Component tool bar buttons relevant for Time Graph adjustment.
Table View Active Component Tool bar
Button Description
Show / Hide Channels (Shift + C)
Minimise/Maximise component (F6)
Show/Hide Items Pane
Show Table Graph View
Show Table Grid View
Show Table Graph + Grid View
Show Table Grid + Graph Insert View
Toggle Table Sliced View
Swap Axis
Reverse X Axis
Reverse Y Axis
Interpolate functions (with drop down) ( ‘I’, ‘H’, and Ctrl + H)
Smooth Function
Show/Hide Target (Shift + T)
Show/Hide Trails (Ctrl + T)
Show/Hide Touch Controls (‘K’)
Time Graph View Active Component Tool bar
Button Description
Time graph properties (F5)
Show Datum Cursor (D)
Only available when using imported i2 Pro logged data file.
Zoom Window
Zoom To Cursors (Z)
Horizontal In Up
Horizontal Zoom Out Down
Horizontal Zoom Full Out (F2)
Vertical Zoom Full In (Alt + Up)
Vertical Zoom Out (Alt + Down)
Vertical Zoom Full Out (Alt + F2)
Logging View Active Component Tool bar
Button Description
Properties (F5)
Repair Log Systems
Import Log System
Export Log System
Clear Log System
Alarms View Active Component Tool bar
Button Description
Show Alarms Event Log
Edit Alarms
Acknowledge All Alarms (K)
