System Requirements
Following are the PC requirements for effective use of MoTeC M1 Tune software.
- Operating Systems:
Windows 10, 64 bit or later.
- Minimum Screen Resolution: 1366 x 768
Recommended screen resolution: 1920 x 1080 or higher
Note: The higher the resolution the greater the screen layout options. - Communications Port:
Ethernet Port
- Communication Protocol:
IPv6
Notes:
- Administrator privileges are required for installation.
- Any active firewalls may need to be updated to
allow:
- Inbound and Outbound Multicast DNS traffic (IPv6) on UDP port 5353
- Outbound XCP traffic (IPv6) on UDP port 5555
- MoTeC i2 1.1.6 or higher is required for data analysis.
- Touch screens are only partially supported; a keyboard and mouse, or touch pad, are required.
