Installing the M1 Tune Application
Note: If during installation, you are prompted to
allow the M1 software to make changes to your PC, always allow; otherwise PC
communications will not work.
The M1 Tune software is provided free of charge and is available as a download from MoTeC Online at https://moteconline.motec.com.au/Home/Downloads
To install the software, the user must have a high enough level of access for the installation software to be able to make the appropriate updates to the PC. This may require the software to be installed by an administrator.
Once the software is installed, the M1 Tune icon is available from the desktop. Use this icon to start the M1 Tune software. Alternatively select Start > All Programs > MoTeC > M1 Tune.
